9 members (Curt B., Gdads51, Bill Hanlon, 3100RustyParts, Steveoreno, 68ironhead, Otto Skorzeny, Millenimech, joe apple),
83
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,214 Posts1,057,487 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10710 01/19/2004 4:01 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Where can I get huck brake parts?
At a minimum I need a wheel cylinder kit and a (heavy) break shoe return spring for the rear on a 51 GMC 1-ton. I could also use shoes but could clean up the fluid saturated shoe if necessary.
Will any 3/4 ton brake parts work on a 1 ton?
Thanks again
Izzenhood | | |
#10711 01/19/2004 4:36 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | WC kit wagner # is F5367 new WC# F9325 the kit is the same as the 3/4 tone but not the Wc and that is for 52-46 the 53-54 return spring might work it's F36449 | | |
#10712 01/19/2004 3:41 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Chevs of the 40s has wheel cylinders and kits for the 1 ton trucks. I do not know about the return springs. | | |
#10713 01/20/2004 2:46 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Several of the suppliers carry the return springs and most of them carry the kits. Go to the links section and then look at the online catalogs.
I think that you will need new lining. There are places that will reline your shoes or some of the same suppliers carry the shoes, with a core trade. | | |
