12 members (Gdads51, greenie-reddy, Simso, Joe H, 1955 1 Series, Southerntruck, Gib70, 3B, Peggy M, Oswald, Jon G, 1 invisible),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | I acquired a few junked trucks and kept EVERYTHING off of them that wasn't rusted. So frame pcs and front axle etc. I have enough stuff to make my own home made side by side.
If I can narrow the front axel, narrow the rear end and put it all on a smaller frame (c-channel) then I'd be able to use my spare 4 speeds/and extra motor (248) on a power-house "mule) that would fit on a 5x10 trailer. and putting smallest possible tires on it would gear it down even lower.
My question: Is it possible to cut and weld those straight front axles? I know it'll be weak at the weld so I could brace it, but I have to ask if anyone has done this with those old axles? Or if they ever narrowed a rear end? My great-granddad did, but he is passed on. Any advice is appreciated!
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Check with Sids. he has worked a lot of these and has some dropped versions that must require at least heat and bending. Might be able to tell you what to use and what to avoid? http://www.droppedaxles.com/
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not completely clear but it sounds like you want to make a home made Gator? If that's the case and you're not thinking of putting something on the highway the yes, you can weld the front axle. It's forged steel and will take to fabricating like any low carbon steel section. Same thing with the rear housing. Don't know how your going to get things aligned for welding or how you going to shorten the axles but what ever you do, KEEP IT OFF THE PUBLIC ROADS.
DG
Denny G Sandwich, IL
| | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | denny-- that's the plan. I have 30 acres and am tired of getting in and out of my pick up to do chores. If I had a gator type vehicle here just on the dirt/hay it would be handy and fun. I have the alignment parts figured out, but don't think I can weld the axles themselves strong enough. I dont' want to pay for a re-spline on those rear axels...
