| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 184 'Bolter | | 'Bolter Joined: May 2003 Posts: 184 | I installed a new gas tank today in my 52 Chevy (the old one had a hole in it). I can't stop it from leaking around the pipe nipple I screwed into the bottom of the tank. I used teflon tape. When I got the tank, it had a temporary bolt screwed into that hole, and the threads don't quite match my pipe nipple. I used a pipe nipple because that's what was on my old tank. It seemed to thread into the hole just fine, but it never really gets tight enough to be gas-tight. In fact, I could screw the whole thing right into the tank.
What kind of a fitting should I be using? Is teflon tape not the best thing to use?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Apr 2003 Posts: 37 Member | | Member Joined: Apr 2003 Posts: 37 | I am not sure of the size right off but it is a tapered pipe thread on the fitting (at least it is on mine). I have had problems with gas dissolving teflon tape when using it on a carb before
BiggerHammer "The key is in knowing where to hit it" | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Teflon tape will not work with gasoline,,,,,, The fitting should be a tapered thread. You may want to use a brass nipple as it will seat threads better.
