5 members (UtahYork, BC59, KEVINSKI, dt235sd, 1 invisible), 94 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
I installed a new gas tank today in my 52 Chevy (the old one had a hole in it). I can't stop it from leaking around the pipe nipple I screwed into the bottom of the tank. I used teflon tape. When I got the tank, it had a temporary bolt screwed into that hole, and the threads don't quite match my pipe nipple. I used a pipe nipple because that's what was on my old tank. It seemed to thread into the hole just fine, but it never really gets tight enough to be gas-tight. In fact, I could screw the whole thing right into the tank.
What kind of a fitting should I be using? Is teflon tape not the best thing to use?
My dad always told me, "Don't force it, get a bigger hammer".
I am not sure of the size right off but it is a tapered pipe thread on the fitting (at least it is on mine). I have had problems with gas dissolving teflon tape when using it on a carb before
BiggerHammer
"The key is in knowing where to hit it"
Teflon tape will not work with gasoline,,,,,,
The fitting should be a tapered thread. You may want to use a brass nipple as it will seat threads better.
