| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | How should I paint parts that come with that black primer on them? Do I just spray them with grey primer and final sand before top coat? Any help appreciated.
Thanks Craig
Still trying to get ole Betsy back on the road.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's what I do, the EDP is about as good as epoxy primer, no need to do more than wipe down with a grease/wax remover
Bill | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I asked the paint supply shop where I get my supplies that very question. They suggested scuff it, sealer, color, then clear. That is my plan anyway. | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | I have found that the EDP on the repair panels which I have purchased to be fragile and easy to scratch off while fitting panels. For this reason, it is always removed before spraying with epoxy primer. I would like to know where the panels came from that had EDP which is about as good as epoxy primer. Carl
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Like Carl I find that the EDP scratches easily and some of my panel are already scratched up which is why I asked the question.
Carl what do you do to remove all the coating before epoxy primer?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I've found rusty finger prints under EDP... whats that tell ya?
I just sand it off with 80 grit on a circular sander then switch to random orbital for final pass before W&G.
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | What Caso said is also a concern of mine. A Chinese parts stamper is not my first choice for applying the most critical first application of paint. As far as what I do to remove the EDP, I use a Norton paint stripper disc. If you haven't tried one of those on an electric grinder, you are missing out on a must-have tool. It eats paint and doesn't gouge the metal. Carl
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Okay guys, thanks for all the response. I guess I'm off to get some 80 grit and a Norton sand disk!!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Like Bill, I never had any problems with EDP either. Two of the parts I've used with it were OEM GM parts (tailgate and front bed panel), and I have one Goodmark fender. I just did the scuff/seal/prime/paint routine, no problems so far.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, I suspect the Chinese parts comment is why some folks have problems [an AD specific thing  ] I've found US made parts the EDP is like epoxy, hardly even any scuffing from shelf wear and not easy to remove Bill | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | yes, I suspect the Chinese parts comment is why some folks have problems [an AD specific thing  ] I've found US made parts the EDP is like epoxy, hardly even any scuffing from shelf wear and not easy to remove Bill Good point Bill. I think that our panels are dipped into something which is black in color and dries after applied, and nothing more. Carl
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Well I was going to strip my parts down and re-prime but with all the hard to get at areas and number of parts I'm rethinking my approach. I also have a new issue with a couple of parts that have come with the "weld through" primer. I don't know why an inner fender would have weld through primer but that's the way they came. The majority of my parts are from Dynacore and seem to be of good quality. I'd like to just scuff and use two part epoxy before topcoat. Any body have any experience with this approach on both the EDP and Weld Through?
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | If you are referring to the horrible gray primer on the inner-to-outer cowl replacement panels as weld-through primer, I primed over it after welding it into place. As far as the black primered parts, I cleaned them and primed the backsides of the panels, and stripped the paint off of the external surfaces before epoxy primer. Carl
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I have always scuffed and epoxy prime ( or sealer as I and other like to call it) and paint. Anytime I do not know what the product is made from I will use DP40 epoxy primer first. I have been using PPG products for close to 25 years and my father has been using them for longer than that. Any issues I have had have been from me and not the product!
Scuff. Prime. Paint. Done. Move on to something else! | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | I have always scuffed and epoxy prime ( or sealer as I and other like to call it) and paint. Anytime I do not know what the product is made from I will use DP40 epoxy primer first. I have been using PPG products for close to 25 years and my father has been using them for longer than that. Any issues I have had have been from me and not the product!
Scuff. Prime. Paint. Done. Move on to something else! So are you saying that if we can nearly scratch the Chinese black paint off the patch panels with our finger nails, it would be fine to scuff and prime? I know epoxy primer is tough, but if the mystery paint underneath it comes off that easily, I have visions of the final paint coming off in sheets. It would only be necessary to remove this Chinese paint from just the patch panels. Not a big task.
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I don't like to use Chinese parts and have been able to avoid them. If I did have to use them.... Then yes I would remove the chinese crap and then start with fresh chinese metal!! | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | I don't like to use Chinese parts and have been able to avoid them. If I did have to use them.... Then yes I would remove the chinese crap and then start with fresh chinese metal!! The "fresh chinese metal" phrase made me laugh out loud. Thank you for that! Carl
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Okay, I'm going with Carl's approach. Last question on this topic.. what is the Norton strip disk grit that takes the paint off but doesn't damage the metal? Part number or hot link to a supplier maybe?
Thanks all for the discussion on this one it helps a lot. Craig
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | The only Norton disc that I am aware of is blue in color and doesn't have a grit rating. I get mine from Sears.
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Okay thanks. Off to sears to check it out.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Homedepot and lowes have them too. | | | | | Joined: Oct 2014 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2014 Posts: 22 | Try a product From SAIT/United Abrasives called SAIT- Strip goes on a 4 1/2" grinder, wheel p/n 77230. Works great on paint. They make other shaft styles also. | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Thanks for all the tips guys.
