9 members (Greg_H, 68ironhead, wilbur53, WICruiser, Gdads51, Shade Baby, rinemb, Otto Skorzeny, 1 invisible),
243
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Am I correct that the grease cup on the distributor shaft housing has some way of reducing shaft wobble? There is supposed to be a spring inside, holding a brass washer (or something) against the shaft.
If this is true (nothing I've found in the shop manual) how strong a spring do I need?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Have you taken the grease cup off and checked to see if the spring and plug are still there? Too bad Denny Graham is not checking in - I think he IDed the size/composition of that fiber plug. http://chevy.oldcarmanualproject.com/parts/1929_54/154.htmMaybe Pre'68 Dave has info on a source for the spring and plug? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Doubt it will help with the wobble of the distributor shaft. A little grease is pushed in as it works its way out from around the shaft. That's what the spring loaded plunger is supposed to do.
If you have wobble in the distributor shaft you need to either rebuild it or get another distributor. The bushings inside the housing that support the shaft is worn, and perhaps the shaft is too.
Nothing is inside pushing against the shaft. Only grease is pushed through the hole to lube the shaft. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here is my wright-up about it on my blog. My wright-up is more about converting a 1926 distributor to this setup, but the same applies.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As usual, very nice, Dave
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Interesting. Always time to learn something new. Thanks
| | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Roy, The grease cups that I've seen in aircraft and machine tool applications didn't have springs and discs in them. You had to turn the outside cap every once in a while to deliver the grease to the bearing. I agree that it probably would require a hefty spring to have any effect on shaft wobble.
Dave, From the material in your presentation it looks like the intent of the spring and disc is to hold the shaft against the opposite side of the bearing bore. The hole in the nylon disc would vent any pressure developed in the grease between the disc and the shaft. and the only way to get grease into the bearing would be to turn the cup like in other installations without the spring and disc.
That being said, I'd expect that the spring would be mighty stiff. Any idea what the spring K is?- since there is nothing in my distributor cup but dried grease.
Thanks, both.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have many spare original springs. PM me your address and I can send you one.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Make sure you clean out the grease and confirm that you can see the shaft. I have seen rebuilt distributors that have had a bushing installed without drilling the bushing so grease can pass through it to the shaft.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If the spring is stiff enough to have much effect on a wobbling shaft, wouldn't pushing it to one side of the bushing cause even more wear? Eventually would the rotor start hitting the inside of the cap? Now that I think of it, I doubt I ever knew how much clearance was between the tip of the rotor and the tip of the cap.
As Dynasoar pointed out, any grease caps I've ever worked with didn't have the spring and disc, and you had to turn the cap so often in order to make sure grease was pushed into the bore.
Interesting item here. I'll have to read and learn more.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If I remember correctly, the spring won't come out with the cap removed. You have to unscrew the body to get to the spring. It is quite possible to take the cap off, reload it and not be aware of the spring. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | It appears to me that this part serves two purposes. 1) A way to periodically add grease to the shaft. (turn the cap in every 10,000 miles as per shop manual) 2) A way to calm down the wobble of the shaft in order to maintain the correct alignment between the rotor and the distributor cap contacts. It does not take much spring pressure at all to calm down the wobble, since there is no side load at all at the top of the shaft and very little load at the bottom of the shaft where the gears are located. Carl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I think the disc and spring are to maintain constant point gap rather than rotor to cap clearance. I have not seen a broken cap or rotor as a result of the disc and spring missing. With a distributor missing the spring you can clearly see the points gap change while shacking the shaft. I had a 216 in my shop that had a noticeable miss on two cylinders at idle. The customer had tried everything he could think of to fix this. I only needed to open the hood for a few minutes to to see the problem. His distributor had a grease fitting where the grease cup should be. I had seen this before and it is quite common on a rebuilt distributor. It is also common for those rebuilders to leave the disc and spring out. Once I put the disc and spring in the engine miss went away.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | My 42 TM lists the fibre disk as PLUG distributor grease cup bolt DR-1869303
It is included in the repair kit DR-1900561
The spring is listed in the parts diagram, but not the kit. The spring is DR-1845715
So the fibre washer is a wear item, the spring is not.
My 43 GMC Delco Remey distributor does not show the fibre washer or spring.
Must be one of those Chevy things.
