0 members (),
123
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 31 | Guys,
Sharpening the tune of my '50 Half-ton pickup, which I've just gotten back on the road after pulling the head to free sticking intake valves. I set the valve lash hot with #1 at top center (I thought) with the flywheel BB at the pointer on #1 compression and exhaust. Now I learn that the BB is for setting ignition timing and may be up to 5 Degrees ahead or behind true TDC.
My flywheel shows raised radial lines, the BB, c/s and a triangle. What means what? The engine is not original but the SN makes it a '49 rebuild.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Most flywheels are marked like the ones I have pictured in This blog post. I can tell you that the triangle is for checking cam timing. I have never seen a c/s.
See the USA in your vintage Chevrolet! My Blog | | |
