4 members (Still At It, 32Fordpuchoptop, treegrower, 1 invisible), 158 guests, and 3 robots.
Topics128,078
Posts1,056,053
Members48,433
#1069567 11/22/2014 12:09 AM
Guys,
Sharpening the tune of my '50 Half-ton pickup, which I've just gotten back on the road after pulling the head to free sticking intake valves. I set the valve lash hot with #1 at top center (I thought) with the flywheel BB at the pointer on #1 compression and exhaust. Now I learn that the BB is for setting ignition timing and may be up to 5 Degrees ahead or behind true TDC.
My flywheel shows raised radial lines, the BB, c/s and a triangle. What means what? The engine is not original but the SN makes it a '49 rebuild.
Most flywheels are marked like the ones I have pictured in This blog post.
I can tell you that the triangle is for checking cam timing.
I have never seen a c/s.
My Blog
