3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Does anyone know what the bed width of a 39 GMC should be? I believe in 40 they went to a wider bed but i am unsure of what the dimensions were. Since the truck has been around for so long who knows what bed may be on it.Mine measures approx.48 1/2 on the inside and i want to purchase a new tailgate for her and the companies do not offer any dimensional data. Also has anyone purchased a tailgate and has any good or bad experiences with the vendors? As always, thanks for your help......Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi Dale My 39 GMC 1/2 ton has the original bed. The front panel measures approximately 48 1/4 on the inside. The tailgate body measures approximately 47 3/4. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Dale - Check out Mar-K. I got my entire bed from them, quality stuff. Worth a look. George | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I'm confused, my 39 GMC bed is also 48" on the inside but according to Mark-k it should be 45 3/4
The following is from Mark-k web site, I used a 39 chevy because they only list a long stepside for the 39 GMC.
" Selected Make: Chevy Selected Year: 1939 Select the Model of your truck bed: Choose ModelShort Stepside
Short Stepside: Length of bed wood 75 7/8". Inside width of bed 45 3/4" Long Stepside: Length of bed wood 85 7/8". Inside width of bed 45 3/4"
I assumed when I measured my bed somebody had put a 40 bed on it at some point. | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Thanks for the info guys..... Stea, I was under the same impression as you,however i have noticed Chevy and GMC are not in sync with each other. I am guessing GMC went to the wider bed a year before Chevy did. I do not know for sure so i will try to get dimensions from the vendor before i order the tailgate. Again, thanks for the help............Dale
| | | | | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | My 36 GMC has a 45 3/4 wide x 86 long bed. I know that it is the original bed, hopes this helps someone. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Hate to drag this back up but.... My 39 GMC has the 48" bed as stated before but now it has me wondering on the rear fenders. What are the width of 39 fenders compared to the 40? Before disassembly everything lined up as it should, do I have the newer 40 size rear fenders? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi stea From everything I've read the 39 Chev fenders were wider than 40-46 because the bed was narrower for 39. My 39 GMC however, has the same size fenders as my 46 Chev. I've also wondered about the rear fender width on the 39 GMC. It may be as Dale suggests, GMC was ahead of Chevy on increasing the bed width. GMC More Power More Payload :p | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Sounds logical because if it had the wider fenders on the wider bed I dont see how the running boards would match up. Does anybody have the actual fender width measurements? | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Cool  I learned something new today about the 39 GMC. | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Stea, my fenders are approx 11 inches wide give or take some, however these are glass fenders that the p.o. put on. I have done some research and am still unsure about the bed width though it seems the few of us here with them the beds were 48 inches wide. In the meantime while pondering which tailgate to order I noticed a nice flat piece of 3/32 steel in the corner of the garage and the lightbulb went off,why buy when i can make my own. It turned out great, and since this is a street rod it did not have to be stock in appearance. I would have had to cut up the repop any to do what i wanted, now i have 300.00 extra bucks for beer  ...Dale
