4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
Getting ready to mount the hood on my 1950 3800 and debating whether to put some type of lining on the underside of the hood. The truck has a rebuilt 235 so I can't imagine it'll generate a whole lot of heat what with all of the open area under there. I painted the underside same color as the outside base/clear though it sounds like originally the underside was just painted with black primer. Thoughts? Suggestions?
I've used that foil covered bubble-stuff on other vehicles but with such a rounded shape I'm worried about getting good contact and a smooth fit.
Bruce
the bubble foil can be formed pretty well, with a few slits where needed to fit strong curves .... but definitely not needed, and I wouldn't expect it to hold up well for a long time
Heat was never an issue for the hood of mine. And it was a very low end paint job. The engine and exhaust are pretty far away from any paint. I wouldn't worry about it.
Dennis
40 Chevy 1/2 ton
