3 members (SmalltownTRKGuy, Southerntruck, Hotrod Lincoln), 147 guests, and 0 robots.
Topics128,195
Posts1,057,369
Members48,469
#1068105 11/13/2014 8:38 AM
Have original 6 lug drum on front. Would like to upgrade to disc but keep 6 lug. What wheels can I use?? Any pics would help. Thanks, don
The sky is the limit. Do a google image search for 6 lug wheels: https://www.google.com/search?q=6+lug+wheels&client=firefox-a&hs=N3I&rls=org.mozilla:en-US:official&channel=sb&source=lnms&tbm=isch&sa=X&ei=LtFkVOaLDsSgyASM74CQAQ&ved=0CAkQ_AUoAg
My '65 had 6 lug 80's truck rally wheels:
http://i645.photobucket.com/albums/...rchased%20Aug%202008/65ShortStepRims.jpg
http://i645.photobucket.com/albums/...hased%20Aug%202008/65ShortStepRear75.jpg
I changed to 6 lug aluminum slotted mags:
http://i645.photobucket.com/albums/...20GM%20Rally%20Caps/Rear_zpscec1d6a7.jpg
http://i645.photobucket.com/albums/...Status%20Photos/GEDC0535_zpsc951c34d.jpg
Hope that helps with your question thumbs_up
jetmech6868 #1068215 11/13/2014 10:23 PM
What should the setback be?? Been told original won't fit.
jetmech6868 #1068220 11/13/2014 10:46 PM
More important than backspacing is the actual design of the wheel itself. If it isn't designed to clear the caliper on a disc brake system it may not have the required clearance on the inner surface of the rear backspacing portion of the wheel itself.
Hope that makes sense to ya.
