| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I went to install the windlace around the door opening on my '51 I have the channel up the back across the top but nothing in front from the top of the windshield down to the floor to slide it into. I replaced the inner cowls but I don't remember removing any channels The others are welded in so they would have had to been drilled off. ?? Maybe previous owner removed when he butched up floors and inner cowls trying to braze patches in. Any suggestions? Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | They should be there. Jim Carter sells (or used to sell) strips of the channel, but too short for your purpose. Probably need to hit a salvage yard with these old trucks or try one of the vendors. | | | | | Joined: Feb 2004 Posts: 10 Member | | Member Joined: Feb 2004 Posts: 10 | I have a 49 truck and I took mine off completely I dont like the rubber around the door. When I put in the new interior I will just go over where the chanels were. | | |
