| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Have original 6 lug drum on front. Would like to upgrade to disc but keep 6 lug. What wheels can I use?? Any pics would help. Thanks, don | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | What should the setback be?? Been told original won't fit. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | More important than backspacing is the actual design of the wheel itself. If it isn't designed to clear the caliper on a disc brake system it may not have the required clearance on the inner surface of the rear backspacing portion of the wheel itself.
Hope that makes sense to ya. | | |
