1 members (TexasA&M48Truck),
67
Mod | | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | What is the best roll-on bed liner kit? Did anyone hear of RustOleum"Road Warrior"? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Hey Napco59,, I do not like seeing anyones post go unanswered. I have not had much experience with do-it-yourself roll-on bed-liner kits.I hope to be able to experiment soon. Have you done any other research on the subject?
| | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I bought a product made by Duplicolor that you roll on with a wild looking roller to give it a lot of texture . I used it on the bottom of my running boards and under/inside the cab . still gotta do the fenders yet . I like it but some way of spraying it would be a LOT easier/faster . | | | | | Joined: Feb 2000 Posts: 50 Member | | Member Joined: Feb 2000 Posts: 50 | bears38... What size roller did you use? Was it able to get into small spaces? How much does this stuff cost?
'52 Chevy 5 window, it ran when I parked it '53 Chevy 5 window, running the streets with me. '55 Massey-Ferguson, tearing up the dirt '89 Harley FXSTS, suicide clutch '92 Harley FLSTC, equal time with the '89
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Bear38, the duplicolor bedliner comes in a spray can also. Your local WalMart should carry both and sure parts houses will also. I used it, spray and roll-on, on the interior of my cab, floor, firewall and recessed areas in rear corners. If you don't want that rough textured look just use a short nap paint roller instead of the wire roller. Another point is, do this job outside in the fresh air with a fan blowing the fumes away from you if possible. This stuff is potent.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
