Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Woodcmiami, frogfarmer, UtahYork, Otto Skorzeny, cmayna), 115 guests, and 2 robots.
Topics128,281
Posts1,058,479
Members48,490
#106775 08/25/2002 1:21 AM
What is the best roll-on bed liner kit?
Did anyone hear of RustOleum"Road Warrior"?
#106776 09/08/2002 11:57 PM
Hey Napco59,, I do not like seeing anyones post go unanswered.
I have not had much experience with do-it-yourself roll-on bed-liner kits.I hope to be able to experiment soon.
Have you done any other research on the subject?
#106777 09/13/2002 4:40 AM
I bought a product made by Duplicolor that you roll on with a wild looking roller to give it a lot of texture . I used it on the bottom of my running boards and under/inside the cab . still gotta do the fenders yet . I like it but some way of spraying it would be a LOT easier/faster .
#106778 09/18/2002 12:53 PM
rat Offline
bears38... What size roller did you use? Was it able to get into small spaces? How much does this stuff cost?
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
#106779 09/18/2002 3:17 PM
Bear38, the duplicolor bedliner comes in a spray can also. Your local WalMart should carry both and sure parts houses will also. I used it, spray and roll-on, on the interior of my cab, floor, firewall and recessed areas in rear corners. If you don't want that rough textured look just use a short nap paint roller instead of the wire roller. Another point is, do this job outside in the fresh air with a fan blowing the fumes away from you if possible. This stuff is potent.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
