7 members (FrankenChevy, 3B, msmall, walter74, Stovebolt48, Shardean, 1 invisible), 63 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#106748 11/29/2002 3:00 AM
Is it necessary to apply primer to the engine block before coating it with engine paint? I would assume that primer does not have the appropriate heat withstand capabilities ?
1951 1 Ton Completed
#106749 11/29/2002 3:36 AM
Others may differ but I have always just primered the sheet metal parts, oil pan, valve cover , etc., and sprayed engine paint over the bare block..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#106750 11/29/2002 2:38 PM
The Bill Hirsch company, which sells really good engine paint, advises no primer for cast iron applications.
#106751 11/29/2002 8:01 PM
Thanks for the replies. Now I know how to proceed.
#106752 12/02/2002 2:59 PM
I, too, am getting ready to paint my engine. Currently the engine is painted blue. I plan to go back to the original grey. The blue paint is in good shape and adheres well, but the engine is pretty dirty and greasy.
Is cleaning up the engine with a good degreaser good enough or should the old paint be removed? Does it need to be media blasted?
#106753 12/03/2002 12:41 AM
Clean it up and degrease it. Any paint that stays on after that deserves to be there. You can paint over the old stuff, as long as it was cured by running the engine for a while. Don't sand blast it, you will get it inside the motor.
Paint & Body Shop moderator
#106754 12/03/2002 2:35 AM
I cleaned my block up with Polyclense, a cleaner which is made for cleaning paint brushes. I used rubber gloves and a brush. It took the best part of a day but it removed 50 years of grease, farm dirt etc. right down to the gray cast iron. It even removed surface rust.
#106755 12/10/2002 10:00 PM
I bought the engine kit from por-15. followed the instructions and it turned out fantastic...brush on-dried like it was sprayed-NO brush marks.
63 K10 Fleet 454
