7 members (HandyAndy, gswbbc, baldeagle, tclederman, 57 Drifter, Cosmo, 1 invisible),
149
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | I might have a chance to trade for a 64 C-10. Owner says that it has a 250 cu in motor and granny 4 speed. From what I've researched so far, the 250's were in a 66, but not 64. No real worries there since it'll be something to play with and I'm not looking for a show truck. My biggest question so far is how they run on the highway with the 4 speed and 250 engine. Any ideas on the stock gearing for a 64? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I hear most folks with a 1964 1/2 ton say they have a 3.73 rear diff. Fourth gear has a 1:1 ratio and is no advantage over a 3 speed which is also 1:1. With a 235/75/15 tire (29" tall), your RPMs will be right at 2600 at 60 MPH with the 3.73 rear. They'll be 2800 at 65 MPH. Worse still if you go with a smaller tire diameter.
If you have a 3.42 rear then you'd be better off but still have higher RPMs than you'd like.
Some folks look for a 3.08 rear. | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | 65 will get me to work on the highway. Since it's only a couple of highway miles at most, I think it wouldn't be too terrible. I might see if I can get him to send me the VIN to run a check on what year it really is. I've already got a request in for more pictures so I can see if the rocker panels on both sides are rusting away. If so, I'm going to have to make a really good inspection of the frame to see if it's still in decent shape. Thanks for the info!! | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Scott, be careful, the sickness once it gets you, it spreads rapidly! Patch panels are available for any body rust but frame rust is another mater entirely. Snatch it up and drive it Saturday. BTW I used to have a later model van that had the 250 with a 3 speed on the column and it did 65mph with no problem at all. Good luck.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The new style engine came out in 63. The first ones were 230 cid. The 250 & 230 are externally alike. It may have been replaced with a 250 or the seller is mistaken. Either way it is a good engine & should work well for what you want it for. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I'm currently running a 250 with a car 4-speed in the '65. Good motor...acts like a small block V-8...pulls up well, and doesn't mind higher rpm's.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Every 60-66 has rocked panel rust... Get it an enjoy.
