0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
#1066538 11/04/2014 11:13 PM
How do you get the dome light wire up or down the door post?,I work at it for about 1 hr and could not get it more than 2 ft down the post. Took a mirror and light looked down the post, looks like there is a plate blocking it off. Had to remove the old wire because of mice eating the insulation. I forgot to look to see how it was run before I removed it, my bad. HELP 53 3100
root #1066539 11/04/2014 11:25 PM
Do you still have the roof cardboard in place?
If not, snake a solid-copper electrical wiring down from the top; then, attach the light wire and pull it up.
root #1066541 11/04/2014 11:28 PM
yes, you bad, should have tied a string to the old one before you pulled it out .... need to get a "fish wire" up or down the post to pull the wire with, something that's stiffer than the electrical wire
root #1066552 11/05/2014 12:41 AM
I can't say about a 53, but on my 55.2 I fished a speedometer cable down through the door post to pull the wire back up through. It went fairly easy.
Brian
1955.2 3100 Truck
root #1066565 11/05/2014 1:53 AM
Sir Searchalot
Sir Searchalot
I use one of those shielded cables from a vent or heater lever. Similar to Shaker's cable but smaller. Send it downhill and pull wire back up. I don't know your type truck so that's a general idea.
root #1066569 11/05/2014 2:04 AM
Tomorrow, I will try the ways that are suggested above and hope for the best. root
root #1066571 11/05/2014 2:07 AM
Sir Searchalot
Sir Searchalot
If you don't get it, use a clap on/clap off as seen on TV.
root #1066575 11/05/2014 2:17 AM
Blow a piece of nylon twine through the pillar and pull the wire back through with it.
root #1066603 11/05/2014 4:38 AM
Going along the lines of the other suggestions,,, try to shove a coat hanger wire up thru there.
This kinda reminds me of when they removed my sons kidney stones.......
root #1066611 11/05/2014 4:56 AM
The twine trick is one I learned at the Bomber Plant.
root #1066651 11/05/2014 1:55 PM
There is nothing blocking in the pillar.
Originally the wire was in in place with a series of clips
Look in the back ground of this pic.
...pic...
It will be a difficult task with the headliner in. I'm sure it can be done.
root #1066944 11/07/2014 2:45 AM
Used a 1/16 welding rod from the bottom, up the inside and not the outside like it shows the the manual. Used a remote view device and yes there is a block off plate installed, maybe the PO reworked the pillar because of a wreak. Anyway, the dome wire is in and now back the the rest of the wiring. Thanks for all the input, best site ever. root
root #1596025 01/15/2026 12:08 AM
Had to use an electrician fishing line on my 57 pickup. Its frustrating but it eventually worked after about 10 tries.
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
root #1596029 01/15/2026 12:49 AM
Sounds like a typical fishing trip. Oh and I remember using a stout piece of wire, though thinner than a coat hangar to help pull the new wire up and over.
Craig
root #1596271 01/18/2026 11:16 PM
After trying everything I had I tried the clothes hanger and it worked in about five minutes.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
