| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | How do you get the dome light wire up or down the door post?,I work at it for about 1 hr and could not get it more than 2 ft down the post. Took a mirror and light looked down the post, looks like there is a plate blocking it off. Had to remove the old wire because of mice eating the insulation. I forgot to look to see how it was run before I removed it, my bad. HELP 53 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you still have the roof cardboard in place?
If not, snake a solid-copper electrical wiring down from the top; then, attach the light wire and pull it up.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you bad, should have tied a string to the old one before you pulled it out .... need to get a "fish wire" up or down the post to pull the wire with, something that's stiffer than the electrical wire
Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I can't say about a 53, but on my 55.2 I fished a speedometer cable down through the door post to pull the wire back up through. It went fairly easy.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I use one of those shielded cables from a vent or heater lever. Similar to Shaker's cable but smaller. Send it downhill and pull wire back up. I don't know your type truck so that's a general idea.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Tomorrow, I will try the ways that are suggested above and hope for the best. root | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you don't get it, use a clap on/clap off as seen on TV.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Blow a piece of nylon twine through the pillar and pull the wire back through with it. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Going along the lines of the other suggestions,,, try to shove a coat hanger wire up thru there. This kinda reminds me of when they removed my sons kidney stones....... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The twine trick is one I learned at the Bomber Plant. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Took a mirror and light looked down the post, looks like there is a plate blocking it off. There is nothing blocking in the pillar. I forgot to look to see how it was run before I removed it, my bad. HELP 53 3100 Originally the wire was in in place with a series of clips Look in the back ground of this pic. ...pic... It will be a difficult task with the headliner in. I'm sure it can be done. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Used a 1/16 welding rod from the bottom, up the inside and not the outside like it shows the the manual. Used a remote view device and yes there is a block off plate installed, maybe the PO reworked the pillar because of a wreak. Anyway, the dome wire is in and now back the the rest of the wiring. Thanks for all the input, best site ever. root | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Had to use an electrician fishing line on my 57 pickup. Its frustrating but it eventually worked after about 10 tries.
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Sounds like a typical fishing trip. Oh and I remember using a stout piece of wire, though thinner than a coat hangar to help pull the new wire up and over.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Apr 2024 Posts: 228 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 228 | After trying everything I had I tried the clothes hanger and it worked in about five minutes.
1956 3100 three speed 6 cyl. Stock with a few upgrades. | | |
