1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | We finally get rain in north Texas and 1957 3100 windshield gasket leaks in bottom corner. Gasket and windshield are new. I thought about pushing a little silicone in it but would that just make it leak somewhere else? This has got to be a common problem. Any suggestions?
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | I also installed a new gasket in mine and it leaks at the bottom 2 most outward corners. I have yet to do it but word on the street from all the car shows i went to is to have someone pull back the gasket lip over the cab bending it up and squeeze in some urethane all the way around (use generously. Then after that have someone lift up on the lip that overlaps the glass and follow with the thin viscosity window silicone. Let it ooze out and when dry cut with razor and pull off the rest. Lots of guys with the trucks are doing this.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That radius is very small in those corners and the rubber is hard to keep in place there. Rubber needs to be put on windshield and taped all the way around so that it will obtain "memory" and conform. It has been coiled up in a Chinese bag on a ship and has the wrong "memory", unless you used Steele Rubber Co. Even then, tape it and leave in the sun for a week or warm room. It will not leak if "re-trained" and installed correctly. Also the pinch weld should be checked for straightness/perpendicularity/radius conformity and deburred. Be careful with your intended fix or the glass corner will chip or snap off!!! the "goopy" style fix could make a huge mess.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
