3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#1065733 10/31/2014 11:17 PM
If i bolt the steering arm(part outside frame) to the frame will the chassis tow ok.? Want to take it to a coin op car wash to clean it. Everthing from steering box down is still attached.
what are you towing with.. tow dolly, flat bed, chain, etc?
tow bar,V bar attached to frame
Bigtonka did this a year or so ago. You might want to PM him.
1951 1 Ton Completed
Flat towing with a tow bar requires the steering to be operational.
If the steering wheel is locked, the chassis (any vehicle) will not follow the tow vehicle around corners. It will go straight and the tires will be dragged side ways around the corner.
A connection to the bumper or frame to the ball hitch causes side force that make the front wheels turn and the tow tracks the towing vehicle.
Jim,
Bigtonka had the opposite happen when he first tried to tow his chassis. He eventually had to lock the steering. Here is a link to his post. Towing a Chassis
Instead of towing to the coin op I rented a power washer with propane burner. It heats the water to close to 200 degrees and you get various nozzles to use. I scraped the heavy crap off first to eliminate as much as possible. I soaked the frame with Gunk engine cleaner where it was greasy and used Spray nine to soak the dirty areas. I used my engine hoist to lift the front end up about 5' off the ground so I could blast under neath. I also pulled the wheels off to get all around the assembly. It worked well and got rid of pretty much all there dirt and grease. I have a gravel drive way so I had no issue with harming the asphalt.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Bigtonka's experience is interesting. It must be all about the weight.
I've towed a variety of vehicles with a tow bar. Not my favorite way to tow, I would prefer a dolly, or a chain with another driver, if I couldn't get both axles on a trailer or flatbed.
Anyway a couple of them were without engines or transmissions and they still pulled just fine. The steering was always complete, don't think it would work without it.
I guess if there is no weight on the front at all the caster could make the wheels flop over.
I towed a early-mid 60s 3/4 ton with newwer 1 ton.i had most of a tow bar.bummper was tore in two.I used 2 bolts 1/2" or bigger and 2 pieces of big angle and drilled and bolted to frame.found out longer than origanal tow bar made stearing do funny thingsw.i had to start into corners easy or stearing on towed truck would whip from cramp to cramp
