6 members (3800GUY, BC59, Youngin' Tut 59, Gray_Ghost, dt235sd, 1 invisible), 126 guests, and 2 robots.
Topics128,140
Posts1,056,771
Members48,454
#1066340 11/03/2014 10:27 PM
Moderated
Moderated
Where can I get wheels and what is the proper size?
Thank You
Welcome to Stovebolt. That topic is discussed here often.
Do you want original or custom?
Hi JRS,
Welcome! If you have an original truck and manual steering, drive ability will be best with a tall, narrow tire. I used Yokohama 700R15 tires that closely match the originals. Two benefits to this - the steering effort is quite light and the tall tire improves your effective gearing. If you have power steering and modern diff ratios, then it is a question of aesthetics.
