1 members (keithfielder), 129 guests, and 1 robot.
Topics128,162
Posts1,056,938
Members48,458
For you guys that have changed the ring & pinion gear set s, can you give me some info on how hard it would be do for a feller that does not have a machine shop?
Like are there some special tool one would need? I have had just about everything else apart and never had issues fixing gears, bearings...etc...so the mechanical, following instructions etc.. no problem..
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
What make, year, and size truck?
12 Chevy rear-end ring & pinion gear set
What does the "12" refer to?
I consider the equipment needed at a bare minimum would be a dial indicator with some type of magnetic or clamp mount system, some indicator dye such as Prussian Blue or white lead, and an inch-pound torque wrench for checking pinion bearing preload. 30 or 40 years' experience setting up rear axle gears helps, but I don't know where you can buy that!
Probably going to need a bearing cage and a press for the pinion bearing.
I would assume he's talking about a GM 12 bolt rear end.
Brian
1955.2 3100 Truck
My ignorance shows, as usual - I'll read and learn.
An interesting read/synopsis.
More information on GM 12 bolts.
Yes sir, sorry.. I was meaning a 12 bolt chevy rear end. I have a 64 c-10 with a 5-11 gear. Sort of rough on the pocket book to drive. I was thinking about going as high as I can go without having to change out the carrier(diff case). Maybe a 3.08. The rearend is in great shape. We have always checked it. I just serviced is when I put my truck back together and it is still clean.
Jesus is Lord!
Our Video
10-4 on the 30-40 years exp... Most of the fellers I knew that I would trust to help with with this have died out. I have to take the approach to try something even if it is wrong or cost me more in the end. I am to the point now where I have to go after it if I want the experience.
Jesus is Lord!
Our Video
