1 members (CATMAN),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | For you guys that have changed the ring & pinion gear set s, can you give me some info on how hard it would be do for a feller that does not have a machine shop?
Like are there some special tool one would need? I have had just about everything else apart and never had issues fixing gears, bearings...etc...so the mechanical, following instructions etc.. no problem..
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What make, year, and size truck?
12 Chevy rear-end ring & pinion gear set What does the "12" refer to?
| | | | | Joined: Feb 2004 Posts: 29,858 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,858 | I consider the equipment needed at a bare minimum would be a dial indicator with some type of magnetic or clamp mount system, some indicator dye such as Prussian Blue or white lead, and an inch-pound torque wrench for checking pinion bearing preload. 30 or 40 years' experience setting up rear axle gears helps, but I don't know where you can buy that! Jerry
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Probably going to need a bearing cage and a press for the pinion bearing. | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | What make, year, and size truck?
12 Chevy rear-end ring & pinion gear set What does the "12" refer to? I would assume he's talking about a GM 12 bolt rear end.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Yes sir, sorry.. I was meaning a 12 bolt chevy rear end. I have a 64 c-10 with a 5-11 gear. Sort of rough on the pocket book to drive. I was thinking about going as high as I can go without having to change out the carrier(diff case). Maybe a 3.08. The rearend is in great shape. We have always checked it. I just serviced is when I put my truck back together and it is still clean.
| | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | 10-4 on the 30-40 years exp... Most of the fellers I knew that I would trust to help with with this have died out. I have to take the approach to try something even if it is wrong or cost me more in the end. I am to the point now where I have to go after it if I want the experience.
