| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 6 New Guy | | New Guy Joined: Oct 2014 Posts: 6 | I have a 1949 3600 pickup, original 6 cylinder, has been converted to 12 volts before I bought it. Installed new battery, positive cable got hot and terminal burned off cable. Positive/negative connections are correct. Engine did not turn over and starter did not engage. I am thinking that the starter is bad or maybe solenoid or foot starter switch? Any suggestions? Thanks | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Apply 12 volts from a battery charger directly to the positive post on the starter and a good ground and push down on the starter switch on the starter. Starter should spin without engaging the flywheel (since you aren't stepping on the stomp starter). If the starter spins, you may have a bad battery cable (internal corrosion). Carl
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If the cable got hot enough to burn when you installed a new battery you have a big short to ground somewhere.
If it did it when you hit the starter button that's another story. | | | | | Joined: Oct 2014 Posts: 6 New Guy | | New Guy Joined: Oct 2014 Posts: 6 | Thanks. I will try your suggestions and post results. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | I had that happen on an 85 Toyota P/U I drove as a kid. Melted 2 batteries before we figured it might be the starter. It was pulling almost 300 amps for some reason. Have the starter tested.
Good Luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
