| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | OK. I'm stuck! I have been trying to remove the arms from the knearled end that goes into the cab for about 2 hours now. This is on a 51 3100. I think that all is original. There is a small spring wire loop that sticks out from under the arm cap. I have pulled one end out, but I can't remove the other end. Is this the lock? How do I take this apart? It can't be this hard. HELP!!
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | there should be a small clip which goes under the knurled knob. pull it back and arm should pull off. it sounds like you are messing with the spring that supplies pressure to the wiper against the winshield. the spring clip that holds the arm on is very small and just runs down along and under the knurled knob. I think -- I'm 270 miles from our truck and can't run down and look. unbroke
Can U believe it? My wife says: "I want an old pickup truck" so I HAD to buy it!! '50 Chevy 3100 5 window.
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Thanks Unbroke. I've moved that thing every way that I can think of, but I'll try your way again. I guess there is some rust under the cap and that can't help.
Thanks Again.
Mark
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Pulling the little spring back that goes under the knurled knob is the easy part. Then you have to get the knurles to let go. Just keep trying and pry gentle.
Buddy in AK | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Unbroke and Buddy,
Thanks for the help. The clips were resting on the knurled end and not under the edge. I couldn't figure out what they did. With a little patience and some help from you, they were off in about 3 minutes. This was the last thing that I needed to remove from under the dash. My firewall is clean and I'm just about ready to remove the cab. The doors are next. Thanks for the help.
Mark
| | | | | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | I remember that stage -- it was about 2 years ago, or was it 3? I'm just now getting it back together. It seems like almost nothing is easy, but it's still fun! Good luck! Isn't this board the greatest?
