2 members (Guitplayer, 1 invisible),
174
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 | Hi all,
I've had my '46 for almost 30 years and have had my rear spring shackles fail 3 times, most recently last Sunday. The part that fails is always the carriage bolt. Seems like the very slight flexing it does fatigues the metal after several years and they finally break. The bolts that are supplied in the shackle kits are Chinese 307A, which apparently isn't very hard.
What I want to do is to replace all four carriage bolts with Grade 8, or at least Grade 5. Haven't been able to find them at any local hardware type stores. Seems like it would be tough to get a hardware supplier to sell you 4 of something like this - more trouble to them than it's worth. What's everyone's opinion on this. They obviously don't fail very often, but if you're on the road it's a real PITA. Anyone else run into this?
David
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If it's that regular carriage bolt they call the "draw bolt" and it can be a regular hex bolt instead, many Gr 8 available. If it has to be a carriage, post the size and length. That is probably available at McMaster Carr and others (maybe not Gr 8 but SS). You can buy bolts in small quantities many places on the web. If you want help finding, need size and length. The only reason it would have to be a "stovebolt" is head clearance or the square under head is fitted into a square hole. All it does is pull the plates together and hold. Not an AD guy, but don't see why it can't be a hex bolt. Easier to find in Gr 8.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Carbon steel won't fatigue under the endurance limit, which is about half the tensile strength. The fit of the tapered pins into the shackles is usually really tight so the bolt really does almost nothing. Have you replaced the entire shackle assembly? Are the spring eyes in good condition? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I agree Gr 5 is plenty good but if you want Gr 8, I understand. If they break, it's time to get stronger. Be sure, as Sput is saying, that something is not wrong with assembly or another part which is over-stressing this bolt. It does not seam like it is under much load, but I'm not sure. If the plates are not bent after bolt breaks and they are not shifting, one up and one down, then I don't see any stress. Where exactly do the bolts break? Middle? head? nut end? strip? Are the holes in the plates for this draw bolt oblonged? If it's 3/8 bolt it has 1000's of lbs strength. Somethings up. 307A= 60KSI= 60,000PSI. Gr 5= 120,000PSI, Gr 8= 150,000psi as a comparison. Caution: Bolts must be torqued to specs or they may be subject to early failure in some cases. Many online bolts will be Chinese also. It is possible that off shore fasteners do NOT comply with the specs and/or are not made/tempered properly. Are you jumping ramps at car shows? Are you a moonshiner?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It seems like what David says, Imperial sells in 50 and 100 Qty?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Try a farm store. We have Tractor Supply that sells bolts, nuts and washers by the pound. It is quite reasonable. If not try Fastenal. They have a great selection. Have fun and good luck Dan | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | In my opinion, you are shopping for a band-aid for a compound fracture. The only way that the carriage bolt will bend or break is if your spring shackle threaded bearings/pins are severely worn. You will need to separate the shackles from the leaf springs to check them properly. (They will seem tighter than they actually are until you remove the weight of the truck from them.) You will need to check where the bearing ends meet the shackles for a tight fit, and the threaded area of the bearings and pins for excessive play. Carl
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You have a problem with a bushing, probably be a good idea to check it out before something bad happens. | | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 | Thanks for all the suggestions. Yes, I've replaced the entire assembly, bushings and all.
As to where the bolt fails, I'm double nutting it on either side of the outside shackle plate. Looks like the bolt failure is on the inside of the inside nut, if that makes any sense.
The bolts are 3/8" x 3 1/2" coarse thread. I will try some of your suggestions. Seems to me that the only reason a carriage bolt was used is that the shackle plates have square holes in them that (I suppose) keep the bolt from turning at all.
David
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Could be a bushing is to tight and causing it to bind up.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Try not double nutting. Try stronger bolt. Make sure there are no special instructions for that bolt like: don't tighten too tight, etc. Is it only one specific place???? (that would be a sure sign). The square hole is to hold the bolt while tightening nut. Why are you double nutting? 3 times in 30 years is not frequent but odd. No others have reported it that I know of. Don't know if it happened on old parts AND on new parts?? On a 3/8 307A, the shear strength is about 4000 lbs!!! The proof load is about 3300 lbs. A quality Gr 5 will not break.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 | I decided to try bartamos suggestion about not double nutting. When I thought about the failures it occurs to me that the problem is that the double nutting is keeping the bolt from having any flex to it (although this would be very minimal). I'm starting to think that over a period of years and thousands of miles the repeated slight stress at the inside nut is causing metal fatigue eventually. Since nobody else is running into this problem, and lots of folks are using the Chinese replacement shackle kits the problem must be how I'm assembling it. Thanks for all the input. Only problem is that it'll be 5-10 years before I know if this worked. David
| | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | keep everone posted,we will be here. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That's long enough to consider it fixed. I think you are doing the best you can do right now.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2008 Posts: 310 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 310 | Yeah, I'm going to consider it good. Sure is a pain when one of those bolts breaks when you're on the road, though. I carry an extra bolt in my toolbox, but you still have to find the two shackle plates, which can be a bit of a trick. Thanks for your suggestion.
David | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Only thing I can think is putting that much pressure on the shackles would be a bad bushing at the fixed end. It might allow enough movement to shift the shackle end. If that is not the issue then I would look close at the "U" bolts for sure.
Steve H
