1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | My '49 (or early '50) Chev panel has six lug hubs. Does that mean its a 3/4 ton? Jerry
1 1951 Chev Panel with a 350 small block, automatic tranny. 1 2004 Chev 2500 HD pickup... stock 1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There were no 3/4 ton panels in 1949/50.
There was a 1/2 ton with 6 lugs and a 1 ton with 8 lugs.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks for the info. Tim and the link. My truck is 116" wheelbase, 6 lug, 5 1/2" cirlce. Half ton for sure. Thanks. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Generally speaking, 6 lug is 1/2T and 8 lug is 3/4 or 1T on Chevy trucks, as is seen in TC's info. The 6 lug bolt pattern was used on Chevy trucks from about the 30's til now. Some years just on 4X4 and 5 lug on 2X. Cars had 6 lug also but not sure of BC. 6 on 5 1/2, in the metric era, is known as 6 on 139.7
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks guys.... I should have known better. My 2004 3/4 ton Silverado has 8 lugs. It would be lodgical the 6 lug are 1/2 ton. But, I had to ask just to be sure.
Thanks for your patience. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It can get easy to confuse things, as GM has made 3/4 ton trucks with 6 lug wheels over the years. Prewar 3/4 tons were 6 lug, and I believe that '46 was the last year for those (I may wrong about that). With later model trucks, there are 6 lug 3/4 ton trucks in the '88-'98 body style (my Dad actually has an '88 2500 that's 6 lug), as well as some 8 lug 1/2 tons in the '99-'06 body. So your question isn't necessarily invalid.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Did not realize there were C/k1500 8 lug. In my limited research, I have not found any.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They only made for a couple of years, '02-'05, IIRC. They basically took the place of the light duty 2500 3/4 ton with the semi floating rear axle.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks Bill and Bart: Yeah... then throw in the 5 lug wheels on automobiles and I start to get dizzy.:) Thanks, Jerry
