| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I have a 46 1/2 ton grill. It seems to have only the front surface crommed and the sides painted black. Is this the way they did it back in 46?
b51r
b51r
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Quite a few of the chroming places do a bit less in coverage than was probably done at the factory. So they focus on what can be seen. It's possible in order to cover up this sub par finish that they either gave the back side a quick coat of paint, or it was done by the previous owner... | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The side and back surfaces of the original chrome grill were, in fact, a low gloss black. | | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | thank you, you confirmed my suspensions b51r Are repo grills chromed all around?
b51r
