5 members (klhansen, Peggy M, Hanks custodian, dt235sd, Otto Skorzeny), 88 guests, and 2 robots.
Topics128,052
Posts1,055,726
#106499 11/14/2004 7:27 PM
how many quarts are needed of martin senour 5102 primer for a truck cab and doors.do i need more than one coat and if so what is required between coats? thanks
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#106500 11/16/2004 12:22 AM
I used about a gallon on a CJ-5 jeep body I did. I suspect that would be about the same amount of metal as your cab and doors (assuming you are doing inside and out). It depends on what kind of gun you are using, you waste about 25% more with a conventional gun than you do an HVLP.
Paint & Body Shop moderator
