3 members (Otto Skorzeny, 68ironhead, mick53), 95 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
Anyone have a pic of the transmission cover on a 1950 1-ton with a four speed and hand parking brake? I just got my new cover and need to modify it to accommodate the hand brake. I could probably get close but I'd rather look once than buy twice.
Thx- Bruce
1 Offline
I think I have a 1948 with 4 speed and floor hand brake cover. Interested? I just had cam out earlier today. I can take some pictures next week if I can find that cover. Remind me .
Thanks Jerry!
Hi Bruce there are a couple of pictures on my Photobucket page that may be useful to you.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
That's perfect Doyle. Where did you find the replacement with the precut handbrake hole?
Bruce
Not a replacement, original part.
Hi Bruce, I bought a replacement tranny cover from Autobody Speciaties out of Conn.Part #c-376 and was $59 when I got mine two years ago. Good luck, Gerry Lee
Well dang! I cut the hole in cover I got from Carter. It looks pretty good but I would have preferred to just get one.
Gerry Lee - when I pulled the old panel off (or what was left of it), there was a small banana shaped thin steel plate that went over the brake handle. It doesn't look like it attaches to anything but I'm not quite sure whether it should sit immediately under the trans cover, or beneath the foam seal (maybe it was attached to the brake boot?). Any ideas?
Bruce
Bruce, still need that picture? Let me know if you do. Mine is off and in my pile. I can snap a pic if you still need one.
got it sir, but thanks for offering.
Figured out what that little part is - it sits beneath the hand brake foam seal. I'm not sure if it originally was glued to the foam seal but it appears to keep it from slipping forwards and backwards with the brake lever. Pretty clever.
Bruce
Moderated by  Dusty53
