0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
Had the cab of the 48 blasted. There was a lot of "sunburn" on the top surfaces, the rest of the cab had very little rust.
When I got it back I had a problem I hadn't thought about.
The factory had used quite a bit of lead on the cowl to smooth the seams from a few inches up the windshield pillar, across the side of the cowl to the firewall. The stripe was around 3" wide.
The shop had gone over that area too aggressivly and the lead was really chewed up. Took a lot of work to get that area smoothed out .
Apparently the young tech doing the blasting had no concept of lead body work.
I will remember to mention it from now on or maybe mark the areas with a note when I drop one off.
Can I ask what it cost to have your cab blasted? that might be the direction I take with the 53' i think it certainly saves a bunch of time-
thanks
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
I just had my 59 cab sand blasted, epoxy primed Had the firewall painted, under the cab and the dash. $2k
Clem
59 Chevy 3600
New Hampshire
I just got mine back from the media blaster, $340.
http://ssrjim.wordpress.com
It was $350
My media blaster guy charges $70/hr. I took the cab along with other parts, but I would guess it took about 4 hours so it was similar to other posts. I know it seems like a high rate, but worth every penny.
Lots more pictures
Mine is 90 per hour
How are you guys taking the cab down to the blaster? On the frame, on a dolley, in the back of a p/u? Is he getting underneath?
Allen
1974 Stingray Corvette
I put 2 2x4's across the top of the bed and set the cab on them, strap down.
At the blasters they just slip the forks under it and take it away.
Yes, 360 degrees.
I would gladly pay $350 for a good job on the cab, it's so big and bulky.
Allen
I put it on a pallet on a tiny little trailer. Strapped down good.
