2 members (walter74, 1 invisible), 102 guests, and 1 robot.
Topics128,049
Posts1,055,675
#1061815 10/12/2014 7:21 PM
Just had disc brake kit put on front of my 54 with power assist. With sharp braking I'm getting a pull to the right. This can't be right but what's the problem and the fix?
Sticky left caliper, restricted flex hose on the left side, improper wheel alignment or wrong offset of the tread centerline. Was anything else changed besides the brake system, like wheels, tires, or other front end components?
Tapered bearings & dual master were added, I think that's all. They said they aligned it following install.
