2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Just had disc brake kit put on front of my 54 with power assist. With sharp braking I'm getting a pull to the right. This can't be right but what's the problem and the fix? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Sticky left caliper, restricted flex hose on the left side, improper wheel alignment or wrong offset of the tread centerline. Was anything else changed besides the brake system, like wheels, tires, or other front end components? Jerry
| | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Tapered bearings & dual master were added, I think that's all. They said they aligned it following install. | | |
