7 members (Steve L., WICruiser, Bill Hanlon, Bucker, Peggy M, Hotrod Lincoln, klhansen),
68
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | I'm trying to rebuild/fix my original seat. The springs in the bottom are pretty shot and my seat guy is a bit stumped re replacement parts. The frame is OK, but looking for suggestions on replacing/rebuilding bottom springs. Filling Station is the only place that has a kit and its pricy. Any ideas? Is there a make/model of newer seat that fits well? Thanks!!! | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | You may be able to get some replacement springs from the vendor below. http://www.snydersantiqueauto.com/search.php?q=seat+springs&x=0&y=0Keep in mind that each spring row has springs of different height and number of coils. If I recall correctly, the wire diameter of the perimeter springs are heavier gauge than the center springs. | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | There are a few threads about later model seats in the 39-46 cabs. My 42 has a 99-2000ish GM 3rd row. Still figuring the mounting though. Fits great and very comfy | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Is that out of a Suburban or mini van? Thanks again | | |
