1 members (NJC),
65
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | I bought a 1951 3100 that was an abandoned project. Has a rebuilt 235, never fired. There is no starter.I would like to use a starter with a solenoid and eliminate the foot starter. Where, what do find such a starter? I took a starter from another truck I had to the electrical rebuilder to be converted and guy said he couldnt do it. Steer me in the right direction please. Im not sure if the flywheel is a 6v or 12v, how do I tell?. Thanks for the help. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | To determine which flywheel you have count the teeth on the ring gear. Post the tooth count and someone will identify it for you. If its a 6 volt flywheel you could use a starter for a '49 - '54 Chev car, they had a solenoid mounted to the starter. If its a 12 volt you can get a starter for a '60 - '63 Chev pickup with a 235 as it had a starter mounted solenoid. Good luck. | | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Thank you! Flywheel has 119 teeth
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 139 teeth on 6v flywheels
168 teeth on 12v flywheels
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Yes indeed 139, dont tell my kindergarten teacher I cant count. Ok , so can use a 49-54 car starter. Those are 6v , can I give it 12v and still live?? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do not crank too long with 12v and you will be OK.
If your engine is well tuned, it should start in a few seconds of cranking.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe he wants to use a solenoid activated starter. Would that be a problem on 12 volts? | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | A sneaky trick is to fit a 12V solenoid to the 6V car-type starter. I'm pretty sure that's a bolt-on swap, and it won't overload the ignition switch "start" position by carrying a very heavy current to the 6V "pull-in" winding of the solenoid. The 6V armature and field coils will live a long time on 12 volts. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are also 6v solenoid starters available - they were used on some 1955-1st and earlier trucks.
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | There are also 6v solenoid starters available That's the problem- - - -the pull-in winding on a 6V solenoid will draw almost 100 amps on 12 volts. It wipes out the "start" position of a key-type ignition switch. If a 12V solenoid is installed on the 6V starter, it works better. Normal pull-in winding current on a 12V solenoid is close to 50 amps for a fraction of a second until the starter drive engages the flywheel and the hold-in winding is energized. Jerry
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Perfect, thanks guys. The search is on for a 49-54 car starter
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevs of the 40s sold me one a few years ago.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Jerry
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Found a starter and having it rebuilt, thanks for the help! | | |
