2 members (Nick in Manitou, Hanks custodian), 93 guests, and 2 robots.
Topics128,035
Posts1,055,559
I bought a 1951 3100 that was an abandoned project. Has a rebuilt 235, never fired. There is no starter.I would like to use a starter with a solenoid and eliminate the foot starter. Where, what do find such a starter? I took a starter from another truck I had to the electrical rebuilder to be converted and guy said he couldnt do it. Steer me in the right direction please. Im not sure if the flywheel is a 6v or 12v, how do I tell?. Thanks for the help.
To determine which flywheel you have count the teeth on the ring gear. Post the tooth count and someone will identify it for you. If its a 6 volt flywheel you could use a starter for a '49 - '54 Chev car, they had a solenoid mounted to the starter. If its a 12 volt you can get a starter for a '60 - '63 Chev pickup with a 235 as it had a starter mounted solenoid. Good luck.
Thank you! Flywheel has 119 teeth
139 teeth on 6v flywheels
168 teeth on 12v flywheels
Yes indeed 139, dont tell my kindergarten teacher I cant count. Ok , so can use a 49-54 car starter. Those are 6v , can I give it 12v and still live??
Do not crank too long with 12v and you will be OK.
If your engine is well tuned, it should start in a few seconds of cranking.
I believe he wants to use a solenoid activated starter. Would that be a problem on 12 volts?
1951 1 Ton Completed
H Online: Content
A sneaky trick is to fit a 12V solenoid to the 6V car-type starter. I'm pretty sure that's a bolt-on swap, and it won't overload the ignition switch "start" position by carrying a very heavy current to the 6V "pull-in" winding of the solenoid. The 6V armature and field coils will live a long time on 12 volts.
There are also 6v solenoid starters available - they were used on some 1955-1st and earlier trucks.
H Online: Content
That's the problem- - - -the pull-in winding on a 6V solenoid will draw almost 100 amps on 12 volts. It wipes out the "start" position of a key-type ignition switch. If a 12V solenoid is installed on the 6V starter, it works better. Normal pull-in winding current on a 12V solenoid is close to 50 amps for a fraction of a second until the starter drive engages the flywheel and the hold-in winding is energized.
Perfect, thanks guys. The search is on for a 49-54 car starter
Chevs of the 40s sold me one a few years ago.
1 Offline
P M sent
Found a starter and having it rebuilt, thanks for the help!
