7 members (Steve L., WICruiser, Bill Hanlon, Bucker, Peggy M, Hotrod Lincoln, klhansen),
68
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 13 New Guy | | New Guy Joined: Dec 2005 Posts: 13 | I just got my 292 back from being rebuilt and over time have lost the mounts that go onto the motor. I am curious if there are any good aftermarket mounts that I can swap over too. I called Chassis Engineering and they said that they don't have any mounts that are a direct swap. I also tried calling langdons stove bolt and they are out until the 13th. I am new at this and any help would be great, Thanks. | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Tom Langdon no longer offers them either, but he has a link on his website of the people that do. So check out his site for more details.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Dec 2005 Posts: 13 New Guy | | New Guy Joined: Dec 2005 Posts: 13 | Thank you 12 Port, I got someone different at Chassis Engineering and they were able to put together a system that should work. I will see in a few days. Thanks again.
| | | | | Joined: Dec 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 61 | RJ, How did the Chassis Engineering work out? I have the same truck as yours, but I am installing a '64 292. Looks like the bell housing we swapped out will fit fine with existing rear mounts. But, the front seems a bit more problematic. Would like to know if your solution worked okay.
Tom B 1953 Chevy 3/4 ton 3600 1964 292 cu. in. in-line six
