7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | A friend was looking for straight 30w oil for a 235, all that could be found was rotella. It says for diesel engines, can this be used in a 235? Freind said he has used it before .
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any good oil can be used, but there's no reason to use straight 30w, 10w30 is fine and what most use
Bill | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Rotella 30W was highly recommended to me for break-in by the machine shop which rebuilt my 235. I am now running Valvoline 5w30 which my hydraulic lifters seem to like (less clacking when cold). Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've been running Rotella-T 15w40 in my stock '50, 215 since I brought it home 10,000 miles ago. I rebuilt the engine about 5,000 miles ago and continued to use it for and thru the break-in. This isn't a laboratory study that's going to be put under the microscope, these are just old trucks, which will run just fine with just about anything that will lubricate them. Don't be so dang particular about what kind of oil your pouring into them, just keep them full.
dg
Denny G Sandwich, IL
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Ok guys thanks for that info, will tell him it's ok to use rotella 30w.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | My main gripe about using the ultra-thin oils like 5 or 10 weight is the fact that these engines were not built with the hair-splitting super close tolerances of modern engines and they need the cushioning effect of thicker oils. No matter what the upper weight rating happens to be, a cold engine is getting pounded apart when it's trying to lube itself with oil the consistency of water. I use 15W-40 in everything I own, from lawn mowers, to cars, to motorcycles, to tractors. It's a good compromise between cold start flow and cushioning, and hot, high speed lubrication capability. The engines run quieter, and wear less. Jerry
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I've been running Rotella-T 15w40 in my stock '50, 215 since dg Hey DG, did you de-stroke your '50 216 to get that 215, or do you also have sausage fingers? Your Pal,  Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Little bitty fingers ----
or----1 cu.in. of carbon build up. dg
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Jerry What brand of 15W40 do you use? Is Rotella OK? Dave V | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | The Rotella Fleet Diesel 30w oil is formulated for 1993 and older engines, so it says on the label. I use it in all my old engines, lawn mowers, tractors, etc. I also use it my Model A and the 39 Chevy truck with a 216. I've had no problems with it, so far.
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Rotella is great- - - -I used it for many years on a fleet of over the road diesel trucks, and backhoes, dump trucks, etc. Now I use "Traveler" brand oil sold by Tractor Supply Co. or whatever generic 15W 40 Walmart sells in their store brand containers. I strongly suspect that's whatever major brand gets the low bid contract for a particular batch. Jerry
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Rotella is popular but it is a diesel rated oil.. that basically means that it has more aggressive additives for diesel motors. It will work fine in a carburetor gasoline motor. I rarely see Rotella in anything other than 15W40. Funny thing is that Rotella meets an obsolete API spec, CF/CF-2. But that is a good thing... that means it has lots of that magical ZDP that people go nuts over. Only the 10W and 30 meet Allison C-4 spec. And lo and behold that Allison C-4 sped is dead: "Allison C4 fluids are no longer approved for Commercial On-Highway products" ( http://www.allisontransmission.com/service/autoapp/172/viewpage.jsp?ThisPage=12Only the synthetic Rotella oil meets any current spec. But for an old 235... its really good stuff. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I either run Rotella 15w40 (preferred) or Travelers 15w40 in my 49 216 dependent upon which is on sale. When compared side by side the Travelers is alittle darker but otherwise I've not noticed any adverse effects on the old 216.
With the 15w40 I get the following readings: In warm weather cold engine psi = 15, warm engine psi = 13 @ any rpm above idle. In cold weather cold engine psi = 30, warm engine psi = 15 @ any rpm above idle.
20w50 didn't raise any of those above readings noticably and I couldn't find 20w50 anywhere as inexpensive as the 15w40 so thats my oil of choice.
btw, I just picked up a Gal of Travelers 15w40 at my local TSC for $10. It's on sale here for the remainder of the month. I'll be picking up a couple more Gals for the upcoming oil change.
Dave | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | TSC has a sale $10 off 5 Gal of Rotella. Got it in the mail.
