4 members (Otto Skorzeny, Gib70, Uncles51, Leo), 136 guests, and 3 robots.
Topics128,164
Posts1,056,977
Members48,458
#1058358 09/25/2014 1:37 AM
Saw a 235 with dual exhaust and it looked like the owner had cut a hole for an 1 1/2(?)exhaust pipe about 2 inches long to which he'd then welded a 2 inch diameter exhaust pipe and run it back and under the usual set up to the muffler. It looked clean and sounded good. Unfortunately, I didn't catch his name etc.. Anyone here done something similar for a 216? How? And any problems etc.?
Long before the Fenton (and other) split header systems became popular, people would weld a second exhaust pipe flange onto the stovebolt exhaust manifold and weld a blocker plate in, creating a "split" manifold. Done properly, each cylinder in the firing order used a different pipe- - - -1,2,and 3 down the front pipe, and 4,5,and 6 from the rear. Because of the firing order, the exhaust pulses alternated from one pipe to the other. Some people think splitting a stock manifold is better than using Fentons, since the heat riser stays functional and it's not necessary to cobble up some sort of carburetor heat system.
If you don't live in a very cold climate, is manifold heat even necessary??
yes, the stock setup works OK without the flapper functioning, but there is a lot of heat transfer just being bolted together. If you are using something where that juncture is separated, you need some type of heat. If it doesn't ever get below 40 degrees you might not see much difference, but it does make a difference
Jerry, what happens it you don't put in the blocker plate? I am trying to avoid the annoying inline six dual exhaust clatter when you lay into it. I was wondering if leaving out the plate would act similar to a cross-over generally used in the exhaust pipe further down stream. I am also trying to get out of extra work.
Carl
