1 members (GradyB),
117
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 13 New Guy | | New Guy Joined: Apr 2012 Posts: 13 | I have a '63 GMC 4x4 3/4 ton pickup and need a pair of front leaf springs. Is there a source for them, or do I need to go to a spring shop to have them made? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | most est spring shops can make them for you. they may not be able to supply the pins ,bushings and shackle kits though. you may have to shop around for them, but you can get them LM have the best price for the shackle kits about $50.00 less than the others. The shackle pins are threaded in.64-66 are their own sizes(springs) which vary from others. ron | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | Benz Spring in Portland, Oregon has made several sets of factory spec 4x4 leaf springs, U bolts, Correct washers and nuts for my various 1957 through 1966 4x4 projects over the years and I have been Completely Satisfied with every set.
They come ready to install.
Freight has become pretty significant here lately though.
Good Luck, 'Got pix of your truck? | | |
