0 members (),
128
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | it only took a few minutes under the truck to realise what kind of a joker the previous owner was with any repairs or mods hed done - but this new discovery takes the prize.
for some inexplicable reason the two spring perch plates welded to the rear axle are ....not equi distant from the center-line of the axle/truck. so my rear wheels are off center sticking out too much on one side and too little on other....
they are shifted to one side by 2 inches.....weird.
who/why would someone do that?
| | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | My guess is an unfortunate blend of alcohol and an arc welder. | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | or a wannabe dirt track racer
1952 Chevy 3100 Semper Fi !
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Maybe he only had one wheel spacer? Seriously though, that just seems outright . . . . . (you fill in the blank). | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | he was probably working upside down from the way he took the measurements  Bill | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | those crazy ford guys. He thought he was working on a Bronco. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Just make only left turns and you will be just fine!  | | |
