Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (HandyAndy, TUTS 59, GMCJammer51), 277 guests, and 1 robot.
Topics128,290
Posts1,058,566
Members48,492
it only took a few minutes under the truck to realise what kind of a joker the previous owner was with any repairs or mods hed done - but this new discovery takes the prize.
for some inexplicable reason the two spring perch plates welded to the rear axle are ....not equi distant from the center-line of the axle/truck. so my rear wheels are off center sticking out too much on one side and too little on other....
they are shifted to one side by 2 inches.....weird.
who/why would someone do that?
My guess is an unfortunate blend of alcohol and an arc welder.
or a wannabe dirt track racer smile
1952 Chevy 3100
Semper Fi !
Maybe he only had one wheel spacer?
Seriously though, that just seems outright . . . . . (you fill in the blank).
he was probably working upside down from the way he took the measurements grin
those crazy ford guys. He thought he was working on a Bronco.
Gas Pumper
Gas Pumper
Just make only left turns and you will be just fine! wink
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
