3 members (baldeagle, Shade Baby, 1 invisible),
94
Mod | | | Forums66 Topics128,125 Posts1,056,336 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | Hello all,
I purchased a CPP dual master cylinder kit a while back for my '53 3100 restore and am having problems with the mount. CPP isn't very helpful and after reading the other threads here on Master cylinders, I thought I'd see if anyone has any insight into this problem.
I am using the adaptor plate that they claim will mount to the stock brake hardware bracket. As far as I can tell, the stock '53 bracket sticks out too far for the adaptor plate to line up with the brake pedal spindle.
As you can see from the below photo link, looking directly from the top down (front of truck is to the left) on the master cylinder, the brake pedal is aligned on the shaft/spindle but the master cylinder and proportioning valve stick too far toward the center of the truck where I've yet to bolt the original 3 spd back in.
https://drive.google.com/file/d/0B8AGg4Pfg1IHaW93VFZwejdGejg/edit?usp=sharing]mount
I've looked for an after-market bracket that would move the cylinder and pedal out farther (down in the photo), while still keeping the use of the brake/clutch shaft in it's original position. Short of cutting the stock bracket and re-welding, I'm at a loss as all the site claiming to sell bolt-on packages don't appear to be true.
Thanks for looking.
Michael | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I used the CPP dual MC/booster kit on my '52 and it fit requiring slight modification to the transmission cross support. I don't think the dual MC only requires cross member mods. I also removed the proportioning valve from the MC bracket and bolted it directly to the frame of the truck (behind MC). The MC pushrod requires a spacer (about 3/4" or so) in order to bolt up to the brake pedal arm. The bracket and brace (brace probably only needed with booster) that came with the kit bolted directly to the original MC bracket.
BTW, I cannot open your photo as I do not have a Google account and never will.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Michael E, I can't open your picture either. | | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | Thanks for the notes guys. I thought the google link would be a good place to store the photos. Posted on my site here: http://www.cmefx.net/BrakeCylinderMount.jpg
Thanks David for the points. I can move the proportioning valve to the frame, but the main concern (as you can hopefully see in the photo now) is that the bracket (and the cylinder) stick too far out to line up with the brake pedal. The pedal and the center of the dual cylinder should line up and they're off by more than an inch. Perhaps I have an odd mounting position but it sticks out a long way for the old single cylinders?
Thanks again Michael
| | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | David F is dead on that is what you have to do | | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | | | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | Looks like my last reply didn't post The main concern is the alignment of the cylinder with that of the brake pedal. The pedal and the center of the cylinder should line up, but they're off by over an inch. Perhaps I need another frame mount as this one sticks out for the original brake cylinder but these dual cylinders are much wider preventing the two from lining up.
Thanks guys Michael
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Mine came from cpp as well,the bracket has two sets of holes drilled in it. One for mounting to a ford and one set for Chevrolet. Mine bolted up fine to the frame.The spacer provided was about a 1/4" to short,I added a couple washers and it's fine. I believe I also had to cut about a 1/2" off of the adjustable heim joint then rethreaded it. I modified my crossmember to fit around the proportioning valve.
Tim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2014 Posts: 24 New Guy | | New Guy Joined: Mar 2014 Posts: 24 | I bought one of the Performance Online brackets- very similar to this one (probably the same)... Mine came with a little solid bushing that went on the bolt that attached the heim joint to the brake pedal- the bushing took exactly the needed offset to line up the pushrod & the pedal.
Worked like a charm for me.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I didn't have to do anything. The CPP one I got just bolted right up. I have pictures of it on the Bolt Bucket.
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I've installed two of the units without issues.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, Michael, look at the link below my signature.. More Pix in the Bolt Bucket. There are detailed pics there that should help. The shafts do not line up by design. Hope this helps! | | | | | Joined: Jul 2014 Posts: 5 New Guy | | New Guy Joined: Jul 2014 Posts: 5 | Thanks guys for the responses. Once I turned on Signatures, I eventually figured out the offset that Deve mentioned. I'll give that a try.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It will work out great Michael. I went with a 3/4 inch stainless steel sleeve I got from Totally Stainless, but any spacer that gets the job done is just fine. Gotta love those Heim joints!
