7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible), 92 guests, and 3 robots.
Topics128,265
Posts1,058,360
Members48,485
#1059665 10/01/2014 9:44 PM
Hi all I'm trying to replace the tie rod ends on my 1959 viking 60 school bus any ideas where I can find then or what will interchange? I should do it before they fall off!
Sky
3B Offline
Hy sky nighthawk, sorry I missed your post from a couple of days ago, so far all I can find are crosses to the standard duty tie rod ends.
GM p/n 609747 is the left one = Napa p/n NCP2692019 $59.95
GM p/n 609748 is the right one = Napa p/n NCP2692020 $59.95
Gm p/n for the heavy duty left one is 2275620, no cross at Napa
GM p/n for the heavy duty right one is 2275619, no cross at Napa
I'll do some more looking for the Heavy duty ones, you could check Ebay, hope that helps.
I found Ebay listings for one each of the heavy duty tie rods, here is the link (I hope it works)You can actually search for it by part number, and it will come up with the tie rod ends!
http://www.ebay.ca/sch/i.html?_odkw...;_nkw=2275620&_sacat=0&_from=R40
http://www.ebay.ca/sch/i.html?_odkw...0.X2275619&_nkw=2275619&_sacat=0
I bought these from NAPA:
When I search for 609747 or 609748 at NAPA, and click interchange they give me:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Tie-Rod-End-Outer/_/R-NCP2692019_0380125365
And:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Tie-Rod-End-Outer/_/R-NCP2692020_0380125403
My 59 Viking now has the new ones installed.
_________________________
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
