0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
Back when my throttle return spring was lost going down
the road it knocked off the heat riser spring as well.
I had it unhooked over the summer and just hanging on
the shaft. Well with it getting colder I noticed it's
taking longer to get the idle smoothed out so I wanted
to add the spring back to the heat riser. I'm cheap and
wanted a less pricey solution than the $18-27 from the
vendors plus shipping. I began to wonder if a choke
thermostat spring would work if it was removed from the
plastic housing. I spent an hour going through all the
pictures on Autozone's website for choke thermostat.
I found one that visually was similar to the picture of
the heat riser spring. Since it was less than $10 I
thought why not take a chance and see if it'll work.
So I ended up ordering a BWD # TH77 from O'Reilly's
since they could have it the next day.
Saturday morning I set about removing the spring from
the housing. Before & after.
I had to get a razor blade down between both sides of
the spring and the plastic shaft to get it loose. Once
it was loose the inner coil was smaller than the shaft
on the heat riser so I had to work a screw driver in
the coil and get it enlarged. But other than that it
fits perfectly on the heat riser shaft and hits the
post above it. Best thing is once it's warm it allows
the weight to fall over into the closed position where
the previous spring didn't unless the throttle was
goosed. My camera didn't take a clear picture of it
installed I'll try another camera at lunch and link a
picture if I get one.
If you want to get one of these chokes the vehicle I
remember it fitting was a 1970 AMC Gremlin, or its BWD
# TH77, Standard has it as # CV77.
Finally got around to taking the installed pictures, it was raining or cloudy yesterday.
Cold
Hot
Notice that when hot, it's actually pulled away from the pin.
The assembly may rattle a little with the spring pulling away from the pin, but that is much better than not opening all the way.
My Blog
The one I payed the exorbitant extra 8 dollars for from a vendor comes off the spring when warmed up as well. The rattle appears to be in sync with the rattling tailgate, so it goes unnoticed.
Carl
Wow! That's really ingenious, who would have thought?
Ed
Ingenious: I wonder what an extra i/2 turn on the spring would do? Might not come off the spring post, might not open all the way. But it works and it is available and cheap. How much better can it get? Nice thinking.
Steve H
Looks to be much heavier than the proper spring, which brings to
mind two things.
1) could you adjust it since is so heavy?
2) Would it fit in the oh so tender slot? Spreading the slot is
an invitation to disaster, the shafts break orful easy when
you try to spread them apart.
dg
Denny G
Sandwich, IL
Denny, to me it seemed to be the same as the springs from the vendors and seem to adjust easier. It fit in the slot just fine and I actually had to work the inner coil bigger to fit around the shaft.
ODSS President
ODSS President
winner winner chicken dinner
~ Cosmo
1949 Chevy Half Ton
U
U Offline
Thanks for posting this & the part numbers Chad- I'll be able to remember it as 70 Gremlins.
I need the spring, and saving the $8 plus shipping is becoming a very big deal right now.
Brad
Wrench Fetcher, PhD
None of the FLAPS around here had any in stock. NAPA wanted to
add shipping, O'Reilly's said they could have it next day and
didn't add shipping so I was happy with that. You may want to call
around to your local shops. Funny thing is Rockauto actually was
the highest price for that number.
Another model may work but most seemed to be a longer spring with
more coils and I wasn't sure what that would do to the opening
rate or tension.
