1 members (baldeagle), 41 guests, and 5 robots.
Topics128,037
Posts1,055,466
Members48,424
#105944 01/02/2002 8:19 PM
All the truck catalogs list Door Windlace. But my old weatherbeaten Burb doesn't have anything that looks like the pictures, and nowhere have I found where it goes and why? Is it the same as weatherstriping? :confused:
Jim
#105945 01/02/2002 9:26 PM
Jim Carter has alot of burb window items in their catalog if that will help. They also have a tech line #.
Live every day to the fullest for tommorrow never comes!!!
#105946 01/03/2002 3:09 AM
Jimfred,
What year truck do you have?
Side door windlace should be the same on pick-up and suburban trucks (except, perhaps, for the color). By windlace, I am referring to the rubber seal that mounts inside the door frame of the cab and seals the door when it is closed - is this what you are referring to? There is also a rubber seal around the door itself and a lower windlace seal attached to the floor with a retainer.
There were at least 2 styles of windlace between 47-54. As I recall, the earlier type (47 to early 49) had screw-on windlace retainer(s) anfrom late 49 to early 55 there was a track welded to the inside edge of the door opening (the windlace slid into this track).
Tim
#105947 01/03/2002 4:27 PM
Tim,
I have a 1952 Suburban. Is the windlace the same as weatherstripping? If not, what's the difference in function? Thanks!
Jim
#105948 01/03/2002 5:59 PM
Jim,
Different names are used by different people (and sometimes by the same people).
First, I assume you are asking about the side doors.
There is a rubber seal that is glued to the edge of the door - this might be called the door weatherstrip.
There is a rubber seal that goes around the door opening in the cab - this is called the cab windlace and it slides in a track that runs from the floor on the dash side of the door opening to the floor on the rear side of the door opening. This track is spot/tack welded to the cab and is is somestimes rusted, bent, or partially missing).
Let me know if pictures will help (my server is down now, so I am unable to post pictures with this message).
Tim
#105949 01/04/2002 12:37 AM
Tim,
Yes, a picture would help. I checked, and I do have the ridge around the door and bits on rubber. So, if this ridge is intact, and I can install windlace around the door, do I still need weatherstrip too? That sounds redundant. Thanks!
Jim
#105950 01/04/2002 2:13 AM
Jim,
Forgive my photography but one truck is masked for painting and the other is resting for the winter.
Here is a picture of the windlace mounted in the cab, around the door: http://home.nycap.rr.com/lederman/images/cabwindlace.jpg
Here is a picture of the door-seal/weather-strip (poorly installed by previous owner): http://home.nycap.rr.com/lederman/images/doorweatherstrip.jpg
For a good wind/water seal (and a decrease in rattles and wind noise), I would suggest using all seals. I forgot to mention the lower door windlace rubber (held to the floor of the cab with a screwed-on retainer) and that the door seal (weatherstrip) is glued on except at the bottom where there is a screwed-on seal retainer.
If you do not have a catalog of parts, you might want to get one from Chevy Duty (nice pictures). http://www.chevyduty.com/frame-free-cat.html
Tim
#105951 01/04/2002 3:15 PM
Thanks Tim! So it seems the solution is to install both!
Jim smile
Jim
