| | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 27 | I just finished painting my truck (it came out ok for a beginner) & and was told after the job was done that my paint booth was not a good idea. I hung plastic sheeting around the garage to keep the dust & bugs out and the paint contained. I then used 2 box fans for ventilation. I'm now told the plastic sheeting could cause static electricity which of course wouldn't go well with a cloud of paint mist. Any thoughts on this.
Thanks | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | chevypickemup, well, i suppose anythings possible but the chance of causing an explosion in that manner is pretty slim. paint is flammable but not like some people think. some would've told you that fumes going throuhg the motors in the box fans could've caused an explosion. i've worked in steel fab shops for over twenty yrs. & most of the painters i've known smoked & that includes while they were painting! foolishly i've even done it myself. not a problem any more, i quit. some may disagree but when my trucks ready to paint i'm planning on doing it the same way you did. robert. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | In reality, the box fans were much more dangerous, due to their ability to spark. However, if you want to use a temporary paint booth use the cloth coated painter's drop cloths and get them damp before use, that way any static is dissipated by the moisture and the overspray sticks instead of bouncing off.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What kind of paint were you using? Not all paints are dangerous around open flames, sparks, motors, and static electricty. Unfortunately, those "safe" paints usually require that you cover every part of your body and use suppled air. | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | HEY GUYS I dont pop up often. BUT There are no brushes in most moters used in fans any more they are induction moters, You might bet spark from the switch, but even then the vapor consentration would be to low, and then are you pulling air into the both or out, bad air over fan or clean air over fan. If you want something scary think about your fuel pump in some newer cars, [IN TANK]I have opend up a VW pump and they pump gas over the brushes and all. But no air no bang. they also use an electronic spark supresion of sorts, BUT it still looks bad, and i still think about it when im low on gas. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Its not the motors on the fans, its the blades. Box fans have plastic blades and screens, which generate quite a bit of static electricity and will spark. Paint safe fans are made completely of conductive materials, usually metal.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | we used to paint in a shop with a big barrel stove going to keep things warm and plastic hanging to | | | | | Joined: Jul 2004 Posts: 29 Apprentice | | Apprentice Joined: Jul 2004 Posts: 29 | Originally posted by chevypickemup: I just finished painting my truck (it came out ok for a beginner) & and was told after the job was done that my paint booth was not a good idea. I hung plastic sheeting around the garage to keep the dust & bugs out and the paint contained. I then used 2 box fans for ventilation. I'm now told the plastic sheeting could cause static electricity which of course wouldn't go well with a cloud of paint mist. Any thoughts on this.
Thanks I'm doing mine in my garage, just like this. I've hung plastic from the rafters. The furnace and gas hot water heater are even in there.(on the other side of the plastic). As long as you ventilate, I don't think the mist is thick enough to cause any type of explosion. My concern is the smell [censored] off my neighbors...
fifty-one half-ton
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 4onthefloor has the idea that I agree w/. A painters drop cloth wet down works a dream. Wet the area outside and the floor also b4 painting. If you're paranoid about the explosiveness, simply ventilating is good enough but have the fans go towards the door, outside, NOT towards the booth.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Burrell, I've heard of setting up a lawn sprinkler outside your paint area (i.e. in front of your garage door)to cut down on the fumes to the neighbors. Never tried it so can't comment on the effectiveness.
I also plan on pressurizing my homemade booth by having the fans blow into the booth through filters and then exiting through a hole with another filter.
Bob | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Please make sure you read the MSDS for any paint you buy. You may need a supplied air breathing set up. Your health is more important than how your truck looks.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'd think with two box fans running, you'd have to have some super highly flamable paint to cause an explosion.
