4 members (Bill Hanlon, Hotrod Lincoln, crenwelge, 78buckshot), 73 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#105926 05/11/2002 3:23 AM
I had really great luck today repairing the typical cowl dent on AD trucks due to the door swinging open too far. This dent has been bothering me for some time and I've continously put off doing anything with it because I just was not sure of how to approach it. Well, today I came to the point where I was ready to cut the panel out for rust repair. The lines were drawn and I had the cutting wheel ready! Most of the outer cowl and inner cowl was going to be removed to get to the upper portion of the cowl to work the dent out with whatever distortion tool I could work into the area. Well, in a moment of clear thought, before the sparks flew, I decided to try another approach. I made up a dozen or so squared off "fence staples" (also resembling squared off horseshoes) about one inch by one inch from 1/8 inch steel rod (old welding rods without the flux coating). These were tack-welded to the bottom of the dent, about two inches apart. I then used my slide hammer with a hook attachment to gently pull the dent out. What was a dent over one inch deep and 24 inches long is now nearly completely pulled with less than 1/8 inch depression down the center left to fix. Little to no distortion from the pulling occurred. A dent which I thought would be a real bugger actually came out with relative ease. Progress, one step at a time!
Michael Zaic
Dahlonega, GA
52 GMC 150
48 GMC 300
#105927 05/11/2002 3:21 PM
That is the way to do it, sounds like you put some good thought into that one. smile
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#105928 05/13/2002 1:54 AM
Well, after messin' with this dent off and on for a couple of days, I think I'm going to leave it alone now and add just a touch of filler. The lowest area looks like it will need just a minimal coat to smooth it out. I would barely consider myself an amateur and at this point the dent is a whole lot better than what it was before I started! grin Half of the fun in this project is thinking about the various repairs and figuring out the best way to get them done. With all of the info tossed around here on the Stovebolt Page, I at least know which direction to start in. wink
Michael Zaic
Dahlonega, GA
52 GMC 150
48 GMC 300
#105929 05/13/2002 4:02 AM
Now that you are ready for plastic filler, here are my "Basics of Basics" for plastic filler work.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>What ever tools you use the trick is to not add the last "skim coat' till you KNOW that it is all you need. Don't try to block out that first coat, just use it as a base for the LAST skim coat.
I was taught this procedure after doing bodywork for a number of years and it really works well:
Just apply a nice coat of filler (what ever brand, whatever style, we will put that aside right now). Cut that coat NOT to make it perfect, but to get the basic shape and filling you need as a base for the skim coat. You can cut it with 36 40 or 80 depending on how big the area you are working is. In other words, if you can cut it fast with only 80 then do it. But I would say that this would be limited to an application that is no larger than about 8 inches.
If you happen to have a few high spots, see if you can tap them down.
If you have a few low spots add a bit more filler to ONLY those spots.
Re-cut these last low spots you have just filled with the same grit you have been using (most likely 36).
If you now have a surface that ONE skim coat will fill, then apply it. If you don't work with it a bit more, but NEVER add a little here or there and think you will finish it without a skim coat.
If you have a surface that is very close with only a few VERY MINOR low spots like poor feathering onto the metal, poor transitions from one application of filler to another, or from the metal that is "poking" up here and there you can do the LAST skim coat.
This skim coat is very important, you want it to extend over the COMPLETE area, this is well past the damage you have been working. Maybe as much as 3 inches past the plastic that you have applied to "rough" it out.
This skim coat can be regular filler or a polyester glaze like "Icing" or "Polyester glazing putty", that is your choice, I use both depending on the size of the area being worked. Do not use anything that doesn't mix with a hardener. NO, “Spot putty” in a tube, only polyester putties or fillers. If it uses a hardener, it cures to a hard film. The “spot putties” stay soft and can become even softer when the solvent from the primer coats it.
You now run a block, long board, or hog even over this skim coat with a little bit coarser paper than you plan on finishing with to cut off the resin that has surfaced in the filler. I usually just use the 36 or 40 or whatever I have been on the "rough" work. BUT take CAUTION not to cut much off, you want to JUST take the very top, don't really sand AT ALL.
Now finish sanding with your longboard or block or hog or whatever using the finer paper like 80 on a large area or 120 on that small 8" sized area. Block it out to perfection with a nice feather edge to the surrounding metal.
I can't stress enough, the trick is to know when just ONE LAST skim coat will do the job. And apply it COMPLETELY over the surface. If you only one little low spot in the middle, DON'T just do it, skim the ENTIRE thing. You HAVE to have one LAST skim coat over the ENTIRE thing every time. If you get in the habit of this you will do it over and over on every dent you repair and find that you can do just about any dent with just
two applications.
As you sand the filler let the board or block you are using run over the surrounding metal. If you only work on the filler you will sand it too low. You need to keep it as high as the surrounding metal, so use the metal as sort of a straight edge that you run the block or board off of.
Don't worry if you cut through this skim coat here and there. In fact, you WILL most likely cut through. The point of that "LAST SKIM COAT" is that after you add it, you don't add ANY MORE filler. That "LAST SKIM COAT" is just that the LAST filler you add. If you hit a little filler below, or metal, that is normal and fine. The only thing you are looking for at that point is if the panel is FLAT. The filler skim coat is serving no other purpose than to finish you filler work, it is not a "sealer" or anything like that.
You can add fiberglass resin (“A” coat if you have a choice) adding the resin was exactly how I learned from the great Emery Robinson (my personal hero in the auto body world). But remember there was no products like polyester putties back then. When you add resin, that resin comes to the top of the film of filler. It is then something you have to deal with. The whole purpose of the SKIM COAT is to put a layer of filler over the top that is easy to block out with as little effort as possible. You want to be able to concentrate on making the panel FLAT not fighting with gummy resin, sand scratches and the like.
So the polyester putty though expensive is what I use.
How is this for an idea, a co-worker of mine showed me this very obvious tip. smile
Add pour-able polyester putty to the regular filler! What an idea! LOL A little pour-able squirted into the "bondo" really thins it out nicely.
The "LAST SKIM COAT" should be left to cure a good long time. Where you may jump on filler and sand it as soon as it is hard, the skim coat should be GOOD AND CURED for an hour or more. If you can of course, in the production shop you may not be able to wait that long. The benefits of the procedure will not be diminished.
A little added note, I have found that I don't use 36 or 40 grit at all anymore. I went to work at a shop that didn't use the coarser grits so I had to learn not to also. I have found that using just the 80 and then finishing the Skim coat in 120 or 180 works great, even on large panels.
At this shop it was the first time that I wasn't doing my own primer work. This meant that I couldn't “cheat” with a lot of primer and blocking the body work “one more time”. I found that I had to get the work PERFECT, then give it to the painter. I did this in an interesting way, I look at the last skim coat as even a more “final” step. I now look it as “primer”. You see I have used polyester primer, which is like spraying “bondo”. They are both polyester resin based and act and sand very much the same. So, I figured why not just “spread out my primer” as the skim coat! It has worked GREAT, the painter jokingly says, “do you think I'll need to prime this or just paint it?” I tell him, “Just clear it, it's a shame to hide that work under primer”.
This method has worked great for me, it's more of a state of mind than a procedure.
And don't be afraid to buy the best sand paper and use a lot of it, the cost of the paper will be nothing next to the time and muscles saved. Find the paint store in town that services the PROS the Body shops in town, that is were you will get the right stuff and the right info.
1948 Chevy Pickup
#105930 05/13/2002 10:46 PM
I'll tell ya what, Martinsr, your basics have been a HUGE help with the work I've been doing. I have little experience with fillers and feel like I can tackle it now and get it right, well, close. :rolleyes: Thanks for sharing!
Michael Zaic
Dahlonega, GA
52 GMC 150
48 GMC 300
#105931 05/14/2002 5:22 AM
Martinsr,
Just wanted to say THANKS! for that info. smile
