| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | So I was told there's going to be lots of clutch head screws on my 41 Chevrolet 1/2 ton I haven't found any does any one know what year they started using them? All mine are slotted flat head in cab Thanks | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | I have a 1941 pickup made in Oct. 1940 in Janesville. It has slotted interior screws. Only 7 or so clutch head screws in the entire truck. I needed some replacement slotted interior screws for it so I took them out of a 1940 pickup. It has philips screws holding on the door hinges
I have a 1941 parts truck made in Dec. 1940 in Janesville. It has clutch head interior screws. The door hinges are also held on with philips screws. Later trucks have clutch head screws holding on the door hinges. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Have done several 41-46 and the door weatherstrip metal strips had clutch head screws. Windshield frame screws were also. Can't remember door panel screws but I think they were also. The reason I definitely remember the weatherstrip screws is if they were seized up the clutch head dimple holds a drill (or bit to you non-machinists) centered.
Evan
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Not sure what month mine is but it was built in Oakland 1212 units in. only clutch screws I've found are one s holding the data plate on so far Oh hindges are Phillips
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Not sure what month mine is but it was built in Oakland 1212 units in. The sequence resets each month. I'm guessing you know that the last 2 digits of the first half of the serial number indicate the month made. Are they illegible? The only clutch screws I've found are ones holding the data plate on so far. On my 1941 made in October, the only places that had clutch head screws were the data plate, the front sections of hood lace, and a tubing clamp on the chassis. | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | its 6AK09 so then its September ?? Thanks | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Have you found anyone that carries the flat head slotted screws I'm missing some? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | My February 41, May 42 and Sep 42 parts truck all have clutch head for nearly everything in the cab less the floor and toe board. Even the door hinge screws are clutch head.
If the truck was messed with in the past, the clutch head screws are often discarded and more common slotted or philips were used.
If you are looking for slotted screws, they are 8-32. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Every single screw on my '41 was clutch head.
Now they are not.
I always chase each screw/bolt hole with a tap before putting a screw/bolt back in to clean the rust and crud out of the threads. The extra step actually saves a lot of time.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | its 6AK09 so then its September ?? Thanks Likely September 1940. This would fit with my observation that only trucks built in the first few months of the 1941 model year have the slotted interior screws. Those slotted screws are not like something you could get at a hardware store (their tips are reduced in diameter and unthreaded) and I have seen the exact same type on a handful of different quite original 1940 and 1941 trucks, so I do not think that they were replaced wholesale later in life. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | My '46 is the same as coil over described. The inner door panel were removed by the PO, so I can't say for certain what the correct fastener should be. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I had a 55 once, and every screw was clutch head. My 57 GMC does not have one anywhere. All Phillips, even the door hinges.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Sput why do you say 1940 ? and I agree these are not at Ace hardware. flat head slotted with a smooth tip I have never seen before The truck sat from 1966 in barn still had original tube radio under dash original headliner dash etc. NO one messed with the screws!! Anyone know a supplier? | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | sput ok I thought about it and figured it out, your saying it was built in Sept 1940 as a new 1941 model year truck GOT IT | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | It seems that the GMC trucks of this vintage commonly used Philips head screws for the interior. I thought that clutch head screws were consistent on the Chevys. I have seen some variability in clutch head fasteners on other parts of the trucks, and date of manufacture did not appear to show a trend. Perhaps assembly plants had some autonomy. The ones I have samples from were assembled in Atlanta and Baltimore.
What is unique about these slotted screws? A picture would say a thousand words. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | You could get close with a Pan Head machine screw. | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Thanks Sput for the pictures those are what I have all interior screws exactly those My truck was built in Oakland if that helps | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Sput,
Thanks for the images, it is often difficult to get such small items in focus but you did well.
Do you think Chevrolet was just starting to use clutch head screws in 1941? Perhaps if we could get some feedback for folks with 1930's model trucks it may help?
The tapered tip certainly aids in installation as those screws are very easy to cross thread in the body sheet metal. I had to repair numerous threads on my cab as the threads were too distorted to properly hold screws. I then drilled and re-tapped for new screws.
Learn something new every day.
Paul
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Round head vs pan head screws.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Clutch head screws were patented in 1933 (1931 filing date). Phillips head screws were patented in 1936 (1934 filing date).
Cadillac was the first GM division to use Phillips head screws in 1936/37.
When GM started using clutch-head screws and when they stopped using them is an interesting question.
